So I have had a code coming on over the last few weeks, code P0496. It is listed as an EVAP code related to the purge valve (up by the oil fill in the passenger valve cover). All other threads I have read concluded with the OP replacing the purge valve which fixed the issue. Mine hasn't.
Troubleshooting so far:
First, I simply cleared the code with HPTuners to see if it came back. Well, it did.
Next I tried tightening the gas cap. It was fine, code still is on.
I then checked voltage at the electrical connection for the solenoid. The voltmeter read 12Volts. This was with the ignition in run, but car off. This brings me to my first question, when the valve is normally closed, is 12V normal?
I then used the HPTuners scan tool to check the canister solenoid valve (one back by the tank), I could here the relay open and close, no problems there. For some reason, the scanner option for the purge valve test was greyed out.
So without testing it, I replaced the purge valve and erased the code. A day later the code came back. Grr!
I read the repair manual for the car, it states that the code P0496 is lit when the purge valve state doesn't match what the car commands. Apparently, P0499 is exclusive to the canister solenoid valve, which I verified to work. I am now at a loss.
The repair manual just mentions a bunch of tests which need weird GM scan tools ans such.
Could I have a wire connection loose? What else can I check? Any other ideas before I give up and go to my mechanic?
