help my brain is exploding.
Been searching for issues similar to mine. I feel like my batteries must be dying or maybe something is loose?
for a good couple weeks my front left tire was acting strange. it would start fine at 38, then you could watch it go down fast like the tire had a huge hole in it but it usually stopped around 4-8 and sometimes would immediately jump back up to 38... (annoying chimes between of course)
it was really sporadic, at first i thought there was a pattern but then it would change... somedays it wouldnt ding. sometimes i could go 20 miles between faults. others it would trip back and forth what seemed like every 5 seconds (which is incredibly annoying)
then it stopped for a week or so. then the front right started going off, only the behavior was totally different, either its not an issue, or it is. it would go off somedays, others it wouldnt bother me at all, but when it did it would just stay low all day and it only goes to the 20s... now both are at it, but the behavior is pretty consistent between the 2, both acting like the front right as described above except the left still goes as low as 4 psi...
totally strange and i havent found other threads similar, but i didnt want to start a new post because this one's title seems close enough, if this doesnt get any attention then i'll start another thread...
I suppose a re-learn wont hurt and maybe i'll do that, but i'm due for a rotation so i'll bring it in and have the tire shop rotate and re-learn.
zepcom? gopher? you guys got any ideas on this?
maybe you've seen a similar post and can direct me there???
