Not that I disagree with you because obviously your much more knowledgable in this department than me or even most people, but how can LS3 heads out power cathedral heads with a good intake?
When I read Pats thread on the other board I was quite convinced that, his is the highest power ive scene made on a NA G8 GT. What NA car has made more power than that? Here is the fist post....
I am so happy, you can't even believe it. Ever since the L92 heads came out, a lot of people think that a cathedral port head can't keep up. I didn't believe it and neither did Tony Mamo from Airflow Research (AFR). I own a 2009 Pontiac G8 with a 6.0L L76 engine. With ARH 1 7/8" headers, FAST 102 intake, Yella Terra 1.85 rockers, ASP 25% UD pulley, and Vararam CAI, the G8 made 397rwhp/395rwtq. This was one of the higher dynoing bolt-on 6.0L G8s. Most 6.0L G8s make in the 420-440rwhp range with bolt ons and a 230/238 cam. The highest number I've seen for a 6.0L G8 automatic has been 470rwhp and this one had ported L92 heads.
Tony Mamo and I decided to go "old school" and take off the Gen IV L92 heads and install a set of AFRs brand new 230 V2 heads. We called this our "Back to the Future Project". I had these heads milled to 65cc chamber so they matched the cc volume of an LS2 head (11.0:1 SCR). Then Tony Mamo did one of his famous porting jobs on a cathedral port FAST 102 intake. We used a fairly mild 231/231 .617/.617" 114LSA +2 advance Comp LSL cam. The gains were staggering: 504rwhp/440rwtq. A gain of 107rwhp/45rwtq. Keep in mind, this is through a locked-up automatic. Most people think that there is little to be gained over L92 heads, but thanks to the huge flow numbers and high airspeed of the AFR 230 and the "mamofied" FAST 102, substantial gains can be had.
There is still more power to be gained with a 102mm throttle body and larger airbox as we were pulling 5-6 kPa vacuum at WOT. Stay tuned for more details on the "Back to the Future Project". There's another 10-15rwhp to be gained with reducing inlet restrictions.
